It is currently Wed Jun 19, 2013 5:41 am
Post new topic Reply to topic  [ 2 posts ]
 Project with screen using tag fro multiple gateway ?
Author Message
Colonel
Colonel
Post Project with screen using tag fro multiple gateway ?
In a large architecture, with 2 or more gateway, I would like to manage a single project connected to all the gateway, with screens using tags from all the gateway with no-copy or a consolided gateway needed.
Is it possible with the 7.4 ? or in next version.
I see the retargeting function, for switching beetween projetc, but if the screen need tag from various gateway, wath is the solution ?
Perhaps there is other way to achieve it ?
:scratch:
Fri May 25, 2012 11:18 am
Profile
General
General
Post Re: Project with screen using tag fro multiple gateway ?
A project running on a particular gateway, can access devices on multiple gateways, or OPC-UA servers.
I my case, the main Ignition server has no local devices connnected. There is also a copy of Panel Edition running on another box and it has the all the devices connected to it. There is also a motion controller by Bosch Rexroth that has an OPC-UA server built in.
When in Designer working on a project on the main Ignition server, when you browse OPC you see all off the OPC-UA servers and their devices and tags.
I can see the Panel Edition and all of the devices connected to it.
I can see the main Ignition server that has no devices attached.
I can see the motion controller and all of the tags declared and published therein.
This is really sweet.
I hope this helps.
Dennis
Fri May 25, 2012 3:18 pm
Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 2 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
