It is currently Mon Sep 06, 2010 4:04 am
Post new topic Reply to topic  [ 25 posts ]  Go to page 1, 2  Next
 The next drivers...
Which driver family are you most interested in?
Automation Direct 25%  25%  [ 11 ]
GE Fanuc 9%  9%  [ 4 ]
Siemens 40%  40%  [ 18 ]
Omron 9%  9%  [ 4 ]
Opto-22 0%  0%  [ 0 ]
Mitsubishi 2%  2%  [ 1 ]
BACnet 4%  4%  [ 2 ]
SIXNET 4%  4%  [ 2 ]
Wago 4%  4%  [ 2 ]
Total votes : 44
 The next drivers...
Author Message
Moderator
Moderator
Post The next drivers...
We've been getting a tremendous amount of feedback on Ignition and our OPC-UA server, and everyone wants to know when driver X will be available. So, we thought we'd put up a poll and see in a (kind of) scientific manner what people are interested in.
Vote for your highest priority driver family, and feel free to post with write-ins and specific models/etc.
Note: MODBUS is not in the poll because it's already been decided that it will be the next available driver. It should be out in about a month.
Fri Jan 29, 2010 5:18 pm
Profile
Colonel
Colonel
Post Re: The next drivers...
I vote to finish the AB suite
Sat Jan 30, 2010 7:14 pm
Profile
General
General
All I use is Modbus and AB, so thats all I really need. Maybe a BSAP driver??
Sat Jan 30, 2010 11:42 pm
Profile WWW
Moderator
Moderator
David, we are finishing the AB suite. Please understand - we're getting requests left and right asking when we'll implement this driver or that driver, so we're just trying to get an idea of what our roadmap will be.
_________________
Carl Gould
Software Development
Inductive Automation
Sun Jan 31, 2010 9:02 am
Profile WWW
Colonel
Colonel
Just voicing my opinion. I am always going to be demanding and persistent. That's the thing I like about IA though.You actually listen to the people that use your product. This is a rarity in this day and age.
Sun Jan 31, 2010 8:29 pm
Profile
Sergeant
Sergeant
Voted for Siemans, hoping this might include a driver for the older Simatic 505 Ethernet stuff :D
Mon Feb 01, 2010 6:26 am
Profile
Captain
Captain
I voted for AutomationDirect, but SIXNET would also be nice.
Mon Feb 01, 2010 6:52 am
Profile
Trooper
Trooper
I guess I wonder what you mean by "Wago". The Wago Ethernet units (750-841 & 750-842) support Modbus TCP, so do you mean you are going to support the export file you can create that will list the tag names and any user defined datatypes created in the CoDeSys IDE and communicate over the same port that the IDE uses?
Just wondering,
Darren
Mon Feb 01, 2010 6:51 pm
Profile
Cadet
Cadet
Hello there!
I also vote for Siemens. I think, at first, the best will be to implement the RFC1006 over TCP/IP protocol!
There are a lot of converters available to connect then to all other Siemens CPUs (including Profibus, MPI and old S5 stuff with TTY Port).
Tue Feb 09, 2010 2:49 am
Profile
Trooper
Trooper
there is one important player currently missing in the list, and that is Schneider. (www.modicon.com)
Secondly, should it be possible to use a custom protocol for data-transfer between two, of more software components without use of OPC. Simple of the fact that OPC takes a lot of money. This is the idea:
[Rs232/485-apparatus A] <- Communication via Apparatus dependent protocol-> [VB/C#/C++ selfmade OPC server] (let's say that the manufacturer has given a activeX or the like to communicate with A.) <- OPC -> [Ignition]. The problem here is the cost to use/made a OPC-server.
Better solution could be: [A] <- Apparatus dependent protocol -> [VB/C#/C++ or Java] <- Direct communication -> [ignition]
With Rsview for example. A VB-program can communicate with RSview via COM(+)
grtz
Wed Feb 10, 2010 4:23 am
Profile
Moderator
Moderator
Well, Lifetec, I guess the question comes down to what exactly the "cost" of OPC is. You mean that you have to pay for the server? Or join the foundation to get access to sample code? Either way, I would say that the cost of custom developing all of your own connectors will be much more in the long run.
OPC is just an abstraction layer that allows driver people to focus on writing drivers, and people who use data to focus on using it, without getting mired down with device details. Sure we could make an API directly in Ignition, but that API would be serving the exact same purpose as OPC (an abstraction layer), but with some serious drawback: would only work with Ignition, wouldn't have industry support, etc.
And RSView gets it's data from RSLinx, which a VB-program can communicate to with OPC, which is nothing else that a set of interfaces in COM.
That's my take on it, at least.
Regards,
_________________
Colby Clegg
Wed Feb 10, 2010 10:41 am
Profile
Trooper
Trooper
Under Siemens it would be interesting to now how many people are using the TI505 line and how many are using the S5/S7 line. I believe the driver is different for the two lines.
And just to nitpick but GE has now divorced from Fanuc and the correct labeling now appears to be GE-IP in big letters and (GE-Fanuc) in little tiny letters to let people know what GE-IP is/was.
Fri Feb 19, 2010 8:20 am
Profile
Major
Major
Any updates on this? Not that I'm being impatient, or anything... :wink:
_________________
Jordan
Duct tape is like The Force. It has a light side, a dark side, and it holds the universe together.
Mon Apr 05, 2010 1:53 am
Profile
General
General
The modbus OPC driver can be downloaded as an separate module on the download page.
Mon Apr 05, 2010 6:43 am
Profile WWW
Major
Major
Thanks, Kyle.
After struggling a bit to get it installed (it helps if you download the correct module), I got thing to work okay. One more driver to go, I can start porting over my project in earnest. :D
_________________
Jordan
Mon Apr 05, 2010 9:05 am
Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 1 guest
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
