I tried another approach, which is to define a folder in my main UDT. Then when I create that instance, I manually add the variable number of child UDTs I need to that folder. However this doesn’t work either, as the the manually added UDT doesn’t inherit the parameter from its parent.
I’m not sure this is what you meant however. I will keep trying other methods to see if i can get it working properly. Maybe you can elaborate on your idea. It shouldn’t be a feature request if there’s an existing way to implement it easily.
Thanks!
