When using templates in windows, I sometimes have a need to access the “internal properties” of the template. I have been able to access those internal properties via scripting, which works fine.
But, it sure would have been easier and “cleaner” if I could have seen those template internal properties in the Ignition Designer graphical tools…………picking them from the object hierarchy.
Sounds like these should be template parameters, not internal properties.
+1 it can be helpful.
Sometimes i need to use internal properties and internal difference bindings. But in window i want to use result of internal properties bindings.
Not helpfull. In your version i must to bind all of not-internal properties.
