It is currently Sat Aug 30, 2014 10:32 pm
Post new topic Reply to topic  [ 7 posts ]
 historizing tags
Author Message
General
General
Post historizing tags
Hello everyone!
Does any knows what is the limit historizing tags with SQL Historian? and with the Historical Group?
Thanks! :thumb_left:
Wed Jul 04, 2012 7:38 am
Profile
General
General
Post Re: historizing tags
what sort of limit? number of tags? number of event per tag? minimum time between events? max time between events?
The answer for all of these is really 'It depends'.
It depends on how fast your hardware is, how much disk space you have to store data, how good your selected database is at storing lots of data, how you partition the data,...
My experience with PostgreSQL has been that it can handle about 5,000,000 rows per table and then it starts slowing down.
Ignition does not impose limits so it really does depends and you have to trial it and see.
Wed Jul 04, 2012 7:54 am
Profile WWW
General
General
I'm trying to historize 160000 tags per second. Is this possible? what are the requirements (hardware) to do this?
Wed Jul 04, 2012 11:42 pm
Profile
General
General
:shock: :shock:
Hadoop? Cray? :twisted:
Is that for one second, one minute, all day every day?
How many tags do you have? I know Kyle has posted about processing 27,000 changes a second. 160,000 changes a second would take a lot of processing power.
You might have to break it up. ie: have multiple history dbs each of which handle some of the total tags.
Let's us know if you get it working and what it took. The IA guys will want to use it for marketing :D
Thu Jul 05, 2012 10:20 am
Profile WWW
Moderator
Moderator
After 24 hours you'd have 13,824,000,000 rows (almost 14 BILLION). I'd say it's time to look at your requirements again?
_________________
Kevin Herron
Software Developer
Inductive Automation
Thu Jul 05, 2012 10:26 am
Profile WWW
Moderator
Moderator
What matters from a computing perspective is how many writes/second you're doing. Keep in mind that you can keep/log aggregate or statistical data, such as min/max/average values from your PLC(s). You can also use deadbands to log significant changes. Realistically, doing anything meaningful with that much data later will be a huge challenge.
If you do in fact have a huge data requirement, I would recommend contacting Kyle. He's pretty savvy with hardware/software/OS/database tweaks. You won't run into Ignition licensing problems, but you may have quite a system to engineer and a lot of data to maintain.
_________________
Nathan Boeger, CISSP-ISSAP, CCNP Voice, VCP
Not Another Industrial Blog - My SCADA software blog
"Design Simplicity Cures Engineered Complexity"
Fri Jul 06, 2012 12:14 am
Profile WWW
General
General
I will contact him. Basically I'm interested in knowing how should be the system (processor, ram, etc)
Thanks for your help!
Fri Jul 06, 2012 2:59 am
Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 0 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
