It is currently Wed Jun 19, 2013 6:32 am
Post new topic Reply to topic  [ 6 posts ]
 Window popup time of day
Author Message
Cadet
Cadet
Post Window popup time of day
I would like to be able to open a window at a specific time of day. Appreciate any help on this.
Fri Jun 29, 2012 8:06 am
Profile
Moderator
Moderator
Post Re: Window popup time of day
You can use a Client Timer Script! You can find it in the designer under Project -> Event Scripts (Client). I would make one that ran every minute and opened the window on a specific time. Just make sure you check the time at the beginning of the script.
_________________
Robert McKenzie
Inductive Automation
Technical Support
Fri Jun 29, 2012 8:23 am
Profile WWW
Cadet
Cadet
Could you give an example of how it would be written. I am quite new to Ignition and the scripting aspect of it all. Thanks.
Fri Jun 29, 2012 8:27 am
Profile
Moderator
Moderator
Code:
from time import localtime, strftime
curTime = strftime("%H:%M", localtime())
print curTime
if curTime == "17:30":
   #it's beer thirty!
   system.tag.write("Beer Cask 1/Flow Control/open", 1)
_________________
Robert McKenzie
Technical Support
Fri Jun 29, 2012 9:08 am
Profile WWW
Cadet
Cadet
thanks works with system.tag.write("Beer Cask 1/Flow Control/open", 1) being replaced with system.nav.openWindow("windowname")
Fri Jun 29, 2012 9:28 am
Profile
Moderator
Moderator
That's correct, although if you're opening a window, system.nav.swapTo("windowname") will be the way to go. This function will properly handle closing the window that was previously in focus and open the new one. If you're just opening a popup, then openWindow works fine.
_________________
James Lorenz
QA/Build Engineer
Fri Jun 29, 2012 9:44 am
Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: diat150 and 1 guest
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
