It is currently Thu May 23, 2013 4:57 am
Post new topic Reply to topic  [ 5 posts ]
 Client tags
Author Message
Cadet
Cadet
Post Client tags
What is the correct syntax to assign a value to a boolean client tag?
Thu Jun 21, 2012 10:03 am
Profile
Moderator
Moderator
Post Re: Client tags
If you're talking about scripting, then you'll use something like:
system.tag.writeToTag("[Client]path/to/tag",1)
More information can be found in the user manual, appendix C under the system.tag library. One more note, as of 7.5 the function name has changed to system.tag.write. Both will work, but the replacement is preferred. Let me know if you have any more questions.
Thu Jun 21, 2012 10:46 am
Profile
Cadet
Cadet
I have a property bound to this client tag.
How would I figure out what property threw a property change event?
Thu Jun 21, 2012 11:17 am
Profile
Moderator
Moderator
Are you talking about within an event handler script? You would call event.propertyName to see which property changed. For an example, look at the "propertyChange Events" section at the bottom of the page of this link:
http://inductiveautomation.com/support/ ... _types.htm
_________________
James Lorenz
QA/Build Engineer
Inductive Automation
Thu Jun 21, 2012 1:34 pm
Profile
Moderator
Moderator
That property change would be what you want to occur or condition to exist that will make that boolean go from 0 to 1. If you have something bound to that tag, say a script or a query, and you want to run it when that boolean >0, you could have that on a button. That is just an example, your going to want it bound to whatever you want to trigger the change of that client tag.
_________________
Greg Simpson
Technical Support Rep
Thu Jun 21, 2012 1:43 pm
Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: BigSchottkyD and 2 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
