Authentification with LDAP OpenDS
I try to connect igntion with the LDAP OpenDS.
Is it possible ?
what is the “Domain” name to use for “dc=example,dc=com” ?? => example.com ???
where are the log, only 2 lines in the console when I active ALL for the level of “authentification” proces.
Enable TRACE logging for “SimpleLDAPAuthenticator”, and you should see more details about whatever is causing the error.
