It is currently Sat May 18, 2013 6:52 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 3 posts ]
 Resizing Windows w\out Resizing Components
Author Message
Trooper
Trooper
Post Resizing Windows w\out Resizing Components
I am trying to resize a pop-up window when a check box is selected. I am resizing in order to show a table that is not normally visible.
It works in design mode, but in run mode the components resize, so the table is still not visible. How can I resize the window, and keep the components at their initial sizes?
Wed Jun 13, 2012 5:20 am
Profile
Moderator
Moderator
Post Re: Resizing Windows w\out Resizing Components
If you set the layout on your components to Anchored to the top and left edges of the screen, then they will not expand to fill the space when you re-size the window. You can do this by right clicking a component and selecting 'Layout' then choosing 'Anchored.'
I hope this helps,
_________________
Robert McKenzie
Inductive Automation
Technical Support
Wed Jun 13, 2012 7:48 am
Profile WWW
Trooper
Trooper
Post Re: Resizing Windows w\out Resizing Components  Topic is solved
Perfect. Thank You.
Wed Jun 13, 2012 8:10 am
Profile
Who is online
Search for:
Jump to:
