Display Timer Component Value in HH:MM:SS format
How can I display with a label component the value of a timer component in HH:MM:SS format?
I have found the following code as a starting point, but with this I get the minutes and hours rounded up.
[code]numberFormat(toInteger({Root Container.Timer.value}/3600),“00”)
  • numberFormat(toInteger(({Root Container.Timer.value}%3600)/60),“00”)
  • numberFormat({Root Container.Timer.value}%60,“00”)[/code]
Try using floor:
numberFormat(toInteger(floor({Root Container.Timer.value}/3600.0)),"00")
+ numberFormat(toInteger(floor(({Root Container.Timer.value}%3600)/60.0)),"00")
+ numberFormat({Root Container.Timer.value}%60,"00")
For future Googlers here is a very quick function to do this using divmod:
def ConvertSecondsToHoursMinutesSeconds(seconds):
	Copied from:
	https://www.geeksforgeeks.org/python-program-to-convert-seconds-into-hours-minutes-and-seconds/
	# Driver program
	n = 65244
	print(ConvertSecondsToHoursMinutesSeconds(n))
	18:07:24
	min, sec = divmod(seconds, 60)
	hour, min = divmod(min, 60)
	return "%02d:%02d:%02d" % (hour, min, sec)
The original intent was to use an expression, not a script. :wink:
That said, new date functions have been added since 2014.
