When I launch an install or upgrade I dont’t find the simulator driver.
How to add this module ?
What simulator module are you referring to?
The PLC simulators should be automatically installed, probably with the OPCUA module. You can create new device connections in the gateway using the simulator.
The simulator device need the module AB/Rockwell driver.
