It is currently Sat May 25, 2013 5:22 am
View unanswered posts | View active topics | View unsolved topics
Page 1 of 1
[ 6 posts ] |
Connect Win911 to Ignition
| Author |
Message |
erikburns
Trooper
Joined: Wed Jun 30, 2010 9:58 am Posts: 27 Location: Sacramento, CA
Can I connect Win911 to Ignition using the OpcCom Module?
Is there any other way to connect Win911 to Ignition so that an Ack get through to Ignition?
_________________ Erik Burns, PE
| Tue May 10, 2011 10:06 am |
jgreenewv
General
Joined: Fri Jan 02, 2009 4:53 am Posts: 160 Location: Jacksonville, NC
 Re: Connect Win911 to Ignition
Erik,
I have used SCADAPhone (very similar to Win911) on a couple of jobs with Ignition. What I normally do for the Ack back to Ignition is set up a dummy register in the PLC, and have SCADAPhone/Ignition look at that register for the "Global Acknowledge." Not the most ideal setup, but it does work.
Thanks. Joe
| Tue May 10, 2011 10:29 am |
diat150
General
| Tue May 10, 2011 4:15 pm |
toasty
Cadet
Joined: Fri Feb 04, 2011 10:34 am Posts: 6 Location: Riveride, CA
You can't directly connect to Win911 using the OPC-COM module. I had to use KepWare, then connect Win911 to Kepware and Ignition to Kepware using the OPC-COM module, you can use OPC-UA to connect to Kepware, but its a few more steps because you have to set up certificates. Also note that the there is a bug with OPC-UA connection dropping out and not reconnecting. I don't know if this has been resolved yet.
Richard
| Tue May 24, 2011 9:51 pm |
toasty
Cadet
Set Win911 alarm to acknowledge on return to normal, then you are going to have to write some script that sets a tag when in alarm condition and resets it when an acknowledge button is pressed in Ignition.
| Wed Jun 22, 2011 10:06 pm |
DaneOverfield
Trooper
TopView SQL from Exele can do what you need by using the SQL tables in Ignition. http://www.exele.com/Products/TopView/topview_about.htmWe have added some details of integrating TopView SQL to Ignition. http://www.exele.com/Products/TopView/s ... /index.htm
| Fri Feb 24, 2012 6:04 pm |
Page 1 of 1
[ 6 posts ] |
Who is online |
Users browsing this forum: No registered users and 1 guest |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum
