It is currently Mon May 20, 2013 12:56 pm
Page 1 of 1
[ 13 posts ] |
| Author |
Message |
JordanCClark
General
Joined: Tue Mar 24, 2009 9:14 am Posts: 660 Location: Hudson, MI
 Crayola colors
Looking for that perfect color to use? http://en.wikipedia.org/wiki/List_of_Crayola_crayon_colorsAlso has hex values...
_________________ Jordan
Duct tape is like The Force. It has a light side, a dark side, and it holds the universe together.
| Tue Apr 19, 2011 7:56 am |
Duffanator
General
Joined: Mon Apr 04, 2011 4:40 pm Posts: 366 Location: Hatfield, PA
 Re: Crayola colors
Nice.
_________________ There are 10 types of people in this world, those who understand binary and those who don't.
Doug Keller Electronics Project Manager Clemens Food Group
| Tue Apr 19, 2011 2:46 pm |
Robert
General
Joined: Tue Feb 24, 2009 1:30 pm Posts: 874 Location: Calgary
 Re: Crayola colors
Now I can color balance my monitors  off to buy a big box of crayons...
| Wed Apr 20, 2011 11:13 am |
Carl.Gould
Moderator
Joined: Sun Apr 02, 2006 2:46 pm Posts: 3759 Location: Sacramento, CA
 Re: Crayola colors
I'll be building a new color-choosing panel to go with the vector drawing tools in 7.3 - maybe I'll add an easter egg to choose by crayola color
_________________ Carl Gould
Software Development
Inductive Automation
| Fri Apr 29, 2011 7:58 am |
JordanCClark
General
 Re: Crayola colors
Carl.Gould wrote: I'll be building a new color-choosing panel to go with the vector drawing tools in 7.3 - maybe I'll add an easter egg to choose by crayola color  Cool! Then I can get my kids to help out on my projects!
| Tue May 03, 2011 1:15 am |
Step7
General
Joined: Thu May 17, 2007 4:56 pm Posts: 491 Location: Ohio
 Re: Crayola colors
If you are working on a new color picker, it might be useful to add a property for the corresponding shadow color value for any selected color. What I'm referring to is the shaded color portion of something like the colored bars in the chart component when 3-D is selected. I had to create a similar chart with the paintable canvas, and all I did was take the rgb values and multiple them by .75 to get something that looked very close to your shading, although I'm not sure if that's correct. It would be that much easier if there was a "shadow" property where this was calculated already.
| Tue May 03, 2011 5:28 am |
Carl.Gould
Moderator
 Re: Crayola colors
What you're describing should be easy to if you use the HSB tab of the existing color picker. HSB is a much better way to deal with colors - RGB is a terribly unintuitive way to represent a color.
Go to the HSB tab, click on the B (Brightness) - pick a color and drag the brightness down a bit - done.
The existing color picker isn't going away, I'm just making an additional one that'll have a better form factor for what I need it for in 2d drawing.
| Thu May 05, 2011 3:38 pm |
Step7
General
 Re: Crayola colors
But, typically I'll use scripting and use an RGB tuple, like Color(128,128,128,255). And to get the consistent shading, I just multiply each value by a constant (i.e. .75). So, if I need to match the colors used in one of your charts, I just pass the color series as a string to another window, and rip through it and create the shadow effect values dynamically, so everything kind of looks the same. Otherwise, if a user wanted to use a different color for an operation, I'd have to configure two new colors. I'm probably explaining this badly, and maybe I'm just doing it wrong.
For instance, in the chart below, you can see the shadow effect just like on one of your charts. If I passed in something "51,102,255,255" for the first bar, what would be the best way to modify each value? I had in mind something like "a=Color(51,102,255,255), and then a.setShadow(0.60) or a.setAlpha(120).
| Fri May 06, 2011 6:29 am |
JordanCClark
General
 Re: Crayola colors
Maybe a new way to typecast a color from HSB values would be a great additon. Something like toHSBColor(h,s,b,a) in expressions, or system.gui.HSBcolor(hue, saturation, brightness [, alpha]) if one be scripting
| Mon May 09, 2011 4:47 am |
Carl.Gould
Moderator
 Re: Crayola colors
Yeah, either of those ideas is fine, but this topic got into the weeds - I was talking about a new GUI, not a way to create colors in scripting. doing RGB each multiplied by *.8 or whatever is a fine way to get a darker color.
| Tue May 10, 2011 1:06 pm |
JordanCClark
General
 Re: Crayola colors
Yeah, but I figured if Carl can do a GUI...
| Tue May 10, 2011 3:14 pm |
Carl.Gould
Moderator
 Re: Crayola colors
in the meantime you can do Code: from java.awt import Color myColor = Color(Color.HSBtoRGB(h,s,b))
| Tue May 10, 2011 3:48 pm |
JordanCClark
General
 Re: Crayola colors
Oh. Well, that was going to be my next question. You beat me to the punch again!
Thanks Carl!
| Wed May 11, 2011 1:26 am |
Page 1 of 1
[ 13 posts ] |
Who is online |
